It is currently Sun Jul 27, 2025 9:16 pm
 Post subject: Which do you prefer?
PostPosted: Sat Apr 24, 2021 11:41 am
First name: Brad
Last Name: Combs
I got around the resawing this set of spalted maple today. Which do you prefer? Bonus points if you know both references. :)
Brad
 Post subject: Re: Which do you prefer?
PostPosted: Sat Apr 24, 2021 11:44 am
Castiel
These users thanked the author jfmckenna for the post: bcombs510 (Sat Apr 24, 2021 1:23 pm)
PostPosted: Sat Apr 24, 2021 12:33 pm
Last Name: Ball
Castiel
These users thanked the author ballbanjos for the post: bcombs510 (Sat Apr 24, 2021 1:23 pm)
PostPosted: Sat Apr 24, 2021 1:11 pm
I'd slip the joint at glue up so that the right side drops down on Castiel to line up some of the patterns
These users thanked the author Mike_P for the post: bcombs510 (Sat Apr 24, 2021 1:23 pm)
PostPosted: Sat Apr 24, 2021 1:37 pm
Castiel too!
These users thanked the author SteveSmith for the post: bcombs510 (Sat Apr 24, 2021 1:47 pm)
PostPosted: Sat Apr 24, 2021 1:52 pm
What if you moved it on up in the top so that the V was kind of holding the rosette
These users thanked the author SnowManSnow for the post: bcombs510 (Sat Apr 24, 2021 2:28 pm)
PostPosted: Sat Apr 24, 2021 2:28 pm
First name: Brad
Last Name: Combs
Yes, this is a good point. There is plenty of real estate to do that.
PostPosted: Sat Apr 24, 2021 2:29 pm
First name: Brad
Last Name: Combs
It’s the back, sorry I should have said that. :)
PostPosted: Sat Apr 24, 2021 2:42 pm
Castiel. You can also move it get more spalt into the outline.
These users thanked the author wbergman for the post: bcombs510 (Sat Apr 24, 2021 3:24 pm)
PostPosted: Sat Apr 24, 2021 4:48 pm
First name: George
City: Seattle
I'll be contrary and go with Daryl. I think it better reflects the angel wings motif. The other way round reminds me of zombies clawing their way up from the fiery pits of eternal damnation ... or something. :D
Either way, it's cool looking wood.
George :-)
These users thanked the author George L for the post: bcombs510 (Sat Apr 24, 2021 6:17 pm)
PostPosted: Sat Apr 24, 2021 5:32 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
I like Daryl, especially if you move the wood down (or the template up) so the peak in the center of the pattern is centered at the waist.
These users thanked the author bionta for the post: bcombs510 (Sat Apr 24, 2021 6:17 pm)
PostPosted: Sat Apr 24, 2021 6:07 pm
Ha and I should have known it :)
These users thanked the author SnowManSnow for the post: bcombs510 (Sat Apr 24, 2021 6:17 pm)
PostPosted: Sat Apr 24, 2021 6:30 pm
OK I can find Castiel and Daryl on the Internet.
Do you build any larger patterns? You seem to be losing a lot of pretty wood.
These users thanked the author wbergman for the post: bcombs510 (Sat Apr 24, 2021 9:20 pm)
PostPosted: Sat Apr 24, 2021 8:43 pm
First name: Brad
Last Name: Combs
It doesn’t quite fit a 00 width wise.
I can’t really put a strip in or anything to try to buy some space.
The set is long enough for up to a dred, just no width.
Ideas?
PostPosted: Sat Apr 24, 2021 9:57 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Taper the center seam on the Castiel pattern to bring the wing tips closer together and they would still be on the upper bout.
These users thanked the author CarlD for the post: bcombs510 (Sat Apr 24, 2021 10:38 pm)
PostPosted: Sun Apr 25, 2021 12:03 am
Last Name: Kincheloe
If you're doing an angel theme, give it some inlays in seraphinite :)
How much too narrow is it? If you use the Daryl configuration, maybe you could weedle out another half inch by using a partial wedge just in the lower half. Glue a piece of the wedge wood to each panel, then cut the new angle and join (the wedge will have a joint up its center). The spalt pattern will be changed a little due to cutting away some of the top middle, but perhaps for the better since you'll get more of the outer "wing edges" into the guitar outline. And of course you only need to reach the inner edge of the binding, unless you're doing an unbound back.
These users thanked the author DennisK for the post: bcombs510 (Sun Apr 25, 2021 6:33 am)
PostPosted: Sun Apr 25, 2021 4:11 am
Maybe no wedge, but wings?
These users thanked the author wbergman for the post: bcombs510 (Sun Apr 25, 2021 6:33 am)
PostPosted: Sun Apr 25, 2021 7:13 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I like Daryl, also it looks like good wood in the center bout so you can have an active back.
These users thanked the author johnparchem for the post: bcombs510 (Sun Apr 25, 2021 11:26 am)
PostPosted: Sun Apr 25, 2021 7:45 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I wonder if you really want to use this for a solid back — laminated, maybe. The stability of wood is compromised by the spalting and there will be increased movement along those lines that will telegraph through any film finish. Ask how I know.
CA might penetrate well enough to stabilize the wood, but the colour changes of the maple might not be to your liking. Testing is essential. My experience is that epoxy does’t really accomplish much.
Personally, I relegate spalted wood to rosettes, head plates, drop tops and other ornamentation.
These users thanked the author Tim Mullin for the post: bcombs510 (Sun Apr 25, 2021 11:27 am)
Users browsing this forum: meddlingfool and 17 guests
